heroxoot's avatar
heroxoot
Apprentice
Nov 27, 2018
Geofilter problems
Im having problems with my GEOFILTER. I can use it if I set my PC to Console but otherwise it wont populate a list. If I do that it wont let my PC connect to some websites or discord servers outside the range.  I just want it set for Unreal Engine for fighting games (Tekken, SFV, SC6, etc). Why won't it populate? My PC has a static IP, set to unreal engine, flushed cloud. What else do I do?
Also, I have an XR450, not 500, but it seems to be the same besides the 2.4ghz band.
  • Hi there - the Unreal Engine will not work for those games unforunately. So the workaround is exactly as you have done (set your PC as a console).
    I'm afraid there's no easy solution to this  - the best thing to do is leave your device in Spectating mode most of the time. But when you go to search for a game, just switch ti back to Filtering Mode. It won't block any active connection (e.g. an open website or a chat service you have going) and it will then filter for the game.
    • heroxoot's avatar
      heroxoot
      Apprentice
      Alright but how do I get it to just allow all connections like this? When I set it up as I have it, it will block stuff outside the radius. It blocked a discord server on me that was right on the outer edge and for a hot 10 minutes I was really confused what was happening.  Do I turn off strict mode? Realistically I just wanna see the ping of the players around me and block people outside NA from playing me.
      • Netduma_Jack's avatar
        Netduma_Jack
        NetDuma Partner
        When you are in Spectating Mode, nothing will be blocked. So only when you search for a game and need the filter to kick in should you switch to Filtering Mode. Then go back to Spectating Mode once you have found a match within your distance range. Does that make sense?
