Dynaxr500
Mar 10, 2020Guide
I lag when my modem (arris) is set on bridge and i get my static public address router xr500
- If you use the DMZ so it is arris (XR in DMZ) > XR500 then you shouldn't have a double NAT as it has a direct line to the WAN. PS4 NAT Type 2 is open it just means it is behind a router compared to Type 1 which is connected to a modem.
let me explain a little better first iam connected with cat 6 (device ps4)i have business cable Internet arris. For some reason when my modem is bridged and i get my static ip i lag in every game and my mic is cutting out constantly. when i get a random public address on bridged again i dont lag but i cant share play on my ps4 to get my static ip i have to put the mac address of my gaming router to get random public address i put my ps4 mac address can u pls help me? if its possible can i use my static ip without having lag? thank u.
- Netduma-FraserNetDuma PartnerWhat is the model of your Arris? You pay for a static public IP but sometimes you get a dynamic public IP? That is quite strange. Do you have an Open NAT on the console? Are you using QoS & the Geo-Filter? If so what settings are you using?
The model is tg862. To able to find my static public ip i have to go to internet setup and put the mac address of the router (xr500) when i play any game i have lag spikes i move my character and it drags me back and my mic constantly cuts off my nat is always open the geofilter i tryed both spectate and filter. to get a randomly ip i just put the mac address of the ps4 i dont lag but i cant share play on the ps4 the nat is open geofilter filter or spectate. the qos i try it with always and disable but nothing changes when i play with the static ip it always lags and my mic constantly cutting of.
