- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
IPV6 not working on XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok so here we go.
1. Model does not show in model for topic.
2. I have owned the following: orginal NETDUMA, XR500 and now the XR1000.
3. My XR500 IPV6 worked fine.
4. IPV6 will not work regardless what I try. Auto config, DHCP or Auto detect on the XR1000.
5. Yes I want to use IPV6 because that is what is recommended by XBOX as well as other websites. Also it worked on my XR500 so....
Just got this today. I only change two things when I get a router. UPNP to on and change IPV6. Please let me know if there is a fix for this. If not I will be sending back pronto.
V/R
Jeremy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: IPV6 not working on XR1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I actually disconnected and am using the XR500. When I first turned it on it made me do an update. So imagine the newest one out there. If you want I can hook it up to see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also it is not a modem. It is the Nighthawk pro gaming XR1000 wifi 6 gaming router. Does not give me a warm and fuzzy that you thought I was talking about a modem. When in the discription I was saying how I could not get the IPV6 to work on the router after I changed it out with my old one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Im also using a CM1000 Netgear modem. Not sure if that what you meant earlier.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Decided to try some troubleshooting.
1. Firmware was lastest version 38. I also tried 36. Both did not work.
2. Rebooted modem, update PC to include windows. On 38 and 36 Did not work.
3. Tried setup wizard on 38 and 36. It also detected DHCP, but still did not work.
Tried Auto config, dhcp and auto detect in firmware 38 and 36. Did not work.
When I look on the IPVS page it is showing DHCP addresses under WAN and LAN. But still does not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fraser was talking about your physical setup: Modem (CM1000) -> XR1000 -> Connected Devices.
The latest version for the XR1000 is 1.0.0.52, I'd suggest upgrading to this and performing a factory reset after the upgrade.
https://www.netgear.com/support/product/xr1000#Firmware%20Version%201.0.0.52
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.downloads.netgear.com/files/GDC/XR1000/XR1000-V1.0.0.52_1.0.38.zip
This is why I put 38.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How have you set up the LAN portion of the IPv6 settings? Not really sure what this means.
The real question is why does it work with the XR 500 and not the XR1000? If I use the exact same settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not have access to that page. It was denied. Can you send a pic of what exactly it is supposed to look like.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok so here is what I did.
1. Uploaded succesfully
2. factory reset
3. The upload was still on the router
4. Tried Auto detect, auto config and DHCP.
5. DHCP is showing.
6. On xbox it is still showing only IPV4 nat open.
Old XR500 used DHCP and xbox did show IPV6
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may need to remove the Xbox from device manager then re-add it and re-configure network settings on the xbox
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried that two ways. Wired and wireless. Still no joy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
no. We use the IPV6 test online.
- Mark as New
- Bookmark
- Subscribe
- Permalink
