Discussion stats
  • 4 replies
  • 1365 views
  • 0 kudos
  • 3 in conversation
Announcements
Reply
Highlighted
Invisible Players Destiny 2
Hello,
I have a Netgear XR500 Gaming Router and in Destiny PvP the enemy players are often invisible. I can shoot them and i see them shooting at me, but still they are invisible.
The only settings that i've changed in the router is Geo filtering (2000 km) and QoS (Playstation priority 1).
What could i have done wrong?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 5
Accepted Solutions
Highlighted
NetDuma Partner
Re: Invisible Players Destiny 2
Glad to hear you haven't experienced it recently, have the other players found what the cause was? It sounds more like a server issue to me and that would make sense if without changing anything it's now working correctly. If it was an issue with the Geo-Filter then you probably wouldn't be put in the game in the first place.
Message 5 of 5
All Replies
Highlighted
NetDuma Partner
That doesn't sound like a router issue, I can't think of anything on the router that would make enemies invisible. I'd suggest maybe looking on the Destiny community sites and seeing if anyone has experienced anything similar.
Message 2 of 5
Highlighted
NetDuma Partner
When you say invisible, you mean you can't see them? Their character models aren't there?
Message 3 of 5
Highlighted
Hi,
Yes, their characters are invisible, as are my equipped weapons.
But i saw that there are also other players experiencing the same problem on Bungie forum.
Haven't experienced it for a couple of days now.
Thanks for your reply.
Message 4 of 5
Highlighted
NetDuma Partner
Message 5 of 5
