aaravksr's avatar
aaravksr
Nighthawk XR1000 Slow Speed
My connection Benchmark speed is 340 Mbps but when I check on speedtest.net and fast.com Then my speed is 100 Mbps. I facing this problem for three days but before three day ago speed was good everything work well and after this problem came I don't know how. I do most of the things like reset / Qos off / check test on other device. But Not solve. If anyone know how to do. Please Help
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    • aaravksr's avatar
      aaravksr
      Firmware 1.0.0.64 Latest. Same cable which comes with router was working fine before with same cable.
      • FURRYe38's avatar
        Have you tired with disabling QoS, reboot the router then test with a wired PC and Ooklas installable speed test app?
        Try speed testing with the wired PC connected to the ISP modem with out the router in the middle?
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
        Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
