- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk xr700, DumaOS not loaded yet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can not set up a wifi signal, when i do it shows the DumaOS not loaded yet page.
Please could someone help me, as i need this working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk xr700, DumaOS not loaded yet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried multiple different browsers same results.
I have tried everything on the forums for similar issues of other devices and they too have not worked.
This seems to be a recurring problem for the xr routers.
What do you suggest i do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- Mark as New
- Bookmark
- Subscribe
- Permalink
I then tried to set up the nighthawk as usual and i cleared my browser data/ cookies etc and reebooted and it says the same thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a different solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will re run it and then can give you screenshots etc, if it still helps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just before the page that says dumaOS is not loaded yet, it shows the page picture i have attached which also seems wrong to me.
If i highlight over it says "www.netgear.com refused to connect"
Not sure if that helps you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure where to go from here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same experience!
I recently upgraded my xr700 firmware to 1.0.1.38 and got the “DumaOS Not Loaded” message. Also my 2.4/5 GHz WiFi were both out, no LED iights. This is similar to what I encountered on my R9000 last year. What happened was that the firmware upgrade for unknown reason corrupted the nvram such that the overlay volume was dismounted. Simple reset through the reset button or 30-30-30 reset will not fix the problem. The only fix is to reset the nvram in the router command line through Telnet. Have to downgrade to an earlier firmware version in order to enable telnet as telnet was not working in the corruption. I was able to fix this on the xr700 quickly as it took me half a year to figure it out on the R9000. Since I fixed it, I have not upgraded to the newer version, at least not yet, perhaps when Duma 3.0 next version is out. Netgear firmware release is unreliable and no one from netgear was able to help on the R9000 when it broke.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
A step by step guide to do this will be very appreciated if you can please 🙏
Thank you for all your help all of you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please see the R9000 procedure in the following link (message 8 of 10) that applies directly on the xr700. They have identical HW.
The trick is really if you can telnet into the xr700. The Telnet Enable line in the debug page http://routerlogin.net/debug.htm
was not there in ver 38, 36, 34 FW. But luckily I found it in 1.0.1.20.
Downgrade your FW under Firmware Upgrade in http://routerlogin.net/adv_index.htm if Duma OS doesn’t take you there.
Use your Windows command line to telnet into the Linux OS of the router.
The attached image showed the missing overlay_volume and the full overlay directory. All fixed after clearing nvram and Duma OS properly loaded.
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
DumaOS not loaded yet!
Don't worry we will redirect you shortly.
I get this message every time I attempt to update my xr700 router. I've tried a 30-30-30 reset dozens of times. I've tried to install every image, including the beta releases. I've submitted this to Level 3 support at Netgear but they haven't replied to me after 5 days. I've offered to send the router itself to Level 3. I purchased a Gearhead support contract. Nothing seems to work. I can get in to the router with routerlogin,net/adv_index.htm and it does support ethernet connections to the internet. Wifi fails. Does anyone have any suggestions as to how I can get past this impasse or get through to Level 3 at Netgear?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried rebooting from the interface without success. I've spent hours on the phone to gearhead support. I'm now trying to TFTP all the images to the router. I get internet access from it but no DumaOS and no wifi. It's very frustrating. And I don't like giving up.
