jteagles's avatar
Nov 21, 2018
Playstation Network problem
Evening all,
Last night got my XR500 working (internet speeds are showing as slower than my isp router but thats for another thread) and tonight Ive put the PS4 on for the first time since using the xr500 and no paystation network.Ive run the connection test on ps4 and the 'obtain ip" -  successful, "internet" - successful, "playstation network" - failed, "Nat" - 2. So everything is fine apart from the psn.Any ideas please?
Thanks.
  • That's strange. I've had it occur sometimes when you have to go to settings and login to PSN first, does that work?
    • jteagles's avatar
      jteagles
      Tutor
      Thanks for the reply mate,
      No that doesnt work.Also I can login no problem through the iphone app
      *update* I just tried to set up a wirless connection to the PS4 and the PSN sign in failed on that too.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Do you have the Geo-Filter enabled? If so disable and try again, does that work? If not try directly connected to the modem/router instead of the XR500 does it work then?
