Egodabossmane's avatar
Feb 20, 2025
Re: Can't Reach This Page, then fixes itself after a second
Power light flashing white no internet connection how do I fix it no wifi connection either anyone got a solution to my problem need help ASAP.
  • Have you tried to access the interface/completed the Setup Wizard if it shows that when trying to access?
  • Power light flashing white no internet connection how do I fix it no wifi connection either anyone got a solution to my problem need help ASAP. I've turn it off for a week still nothing.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      • Egodabossmane's avatar
        Egodabossmane
        how do I do that I cant even connect to the router or wifi have no access at all
