Manuellll's avatar
Manuellll
Apprentice
Oct 01, 2019
Unknown error
someone knows that this error gives me my xr500?
Uncaught TypeError: Cannot read property 'removeChild' of null
  • It is likely nothing to be concerned with. How often does it appear? Does it go away after saying okay?
    • Manuellll's avatar
      Manuellll
      Apprentice
      it is done every time I log into the router gives me that message, another question I broke the cable provided with the netgear cat5e FTP router if I replace it with a cat5e UTP is it a problem could interefernere the router with the modem?
      • FURRYe38's avatar
        What browser are you using?
        Does this happen after a factory reset?
        What FW version is loaded on the router?
