- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Will there be a new one soon?
- Mark as New
- Bookmark
- Subscribe
- Permalink
But with wifi 6/ax on the horizon I don’t know if the upgrade the the XR700 is worth the upgrade since it will soon be old tech.
Hence looking at a switch to ASUS ROG Rapture GT-AX11000 however it’s hardware and OS don’t seem to be as good as the XR700, it doesn’t have a 10GbE, the OS doesn’t seem as good for the prioritisation of BW and it doesn’t have the same media server capability.
That being said I don’t feel like Netgear’s AX12 is comparable to the ASUS if I were to go the Netgear wifi 6 option.
I will be running a synology 6 bay NAS as a plex media server for local and remote access (massive library). 3 gaming consoles, 3 mobiles, 3 laptops, 3 iPads, 24/7/365 torrenting and 3 streaming services. Looking for high processing power so the transcode of 4K over the network is seamless...
Long story short, do I jump ship to ASUS, do I go with the AX12 or do I wait for Netgear to bring out their option of a gaming router with wifi 6 and is that on the horizon?
Let me know what you think.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Will there be a new one soon?
there's also the RAX200 to consider. It was supposed to be released in early July but has been pushed back.
https://www.netgear.com/home/products/networking/wifi-routers/RAX200.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Thomo1318 wrote:
RAX200 = AX12
AX12=RAX120 not rax200.
https://www.netgear.com/home/products/networking/wifi-routers/RAX120.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RAX200 is AX11000 not ax12. Similar devices but with some differences.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looking at the tech specs, apart from the upgrade to wifi 6 the other tech specs still don’t marry up to the RX700
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Thomo1318 wrote:
I stand corrected...
Depends on your usage. Yes the XR700 has 10g port but I don't know of a consumer modem that supports this. The RAX200 supports link aggregation for wan port or using the 2.5g port for wan. More likely to see consumer modems with 2.5g or link aggregation.
Rax has triband so you can separate out devices. Its tough to compare processors as their different suppliers (Annapurna vs broadcom).
Little bit of differences but I'd hold off until wifi 6 has been ratified if you can. I think it'll give time for the firmware to stabilize and truly see a comparison in speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser wrote:
Just my two cents, there are currently no devices that I am aware of that support AX WiFi and so any of your current devices would not see the benefit of that technology even if you had a router that used it.
Samsung S10 supports ax doesn't it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes looks to be one of the first devices, I stand corrected thanks! If you're not planning on buying all new phones, laptops etc then AX won't be of much benefit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not trying to be arguementative but AX does help with standard ac devices for concurrent broadcasts. Its tough to objectively measure since you're using mutliple devices but it subjectively feels faster when I've been testing AX routers 🙂 I don't really notice until I get multiple devices rolling with some decent bandwidth.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
