× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR1000 cant connect to geofilter and pingmap
Sureshot08
I all of a sudden am not able to use or connect to the duma os features geofitler or heat ping map. I have the latest version XR1000 1.0.0.64_1.0.49 have cleared my cache and cant find anyway to get the web browser to work. I am currently using the edge browser
Message 1 of 19
Re: XR1000 cant connect to geofilter and pingmap
That's a specialist thing related to your gaming router.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 19
Sureshot08
XR100 wont load Geofilter and Ping Heatmap
I am unable to access both the geofilter and ping heatmap. every other aspect of the browser and UI work fine but those two either try and load forever or produce the error message rapp wont load wait a minute. I am on version XR1000 1.0.0.64_1.0.49
Heres what ive tried from some other posts:
Setting the rapp retry limit to 5
Downgrading firmware to a few different versions
Using both Microsoft Edge and Chrome
Deleting cache and cookies
Hard resetting router
Message 3 of 19
Netduma-Liam
NetDuma Partner
Re: XR100 wont load Geofilter and Ping Heatmap
Thanks for all the information.
Which firmware versions did you try downgrading to out of interest?
Does rebooting the router temporarily resolve the issue?
Message 4 of 19
Sureshot08
I had try the last two versions 58 and 52 I believe. Rebooting and waiting 2 mins didn't change anything.
Message 5 of 19
Netduma-Fraser
NetDuma Partner
Are you using Armor at all? If so could you disable it, reboot, wait 2 minutes and then see if it loads correctly please?
Message 6 of 19
Sureshot08
I am not. it is disabled
Message 7 of 19
Netduma-Fraser
NetDuma Partner
When did the issue start to occur, after update, settings changes etc?
Message 8 of 19
Sureshot08
It was working fine until yesterday when I attempted to use the ping heat map and it wouldn't load. A few hours later I went to change some geo filter options and haven't been able to access is since
Message 9 of 19
Guru
Be sure to clear out all browser caches before entering the routers web page.
Might try FireFox as well...
Message 10 of 19
Sureshot08
Thank you, I'll give Firefox a shot
Message 11 of 19
Netduma-Fraser
NetDuma Partner
If that doesn't work, reboot the router then wait 2 minutes before accessing
Message 12 of 19
Netduma-Fraser
NetDuma Partner
How are you doing the reset? If the interface, use the hardware reset and vice versa, wait 5 minutes then access please
Message 13 of 19
Sureshot08
So my plan is to start from the beginning. I'm going to delete edge, factory reboot my router and hope that fixes it
Message 14 of 19
Sureshot08
So with a complete factory reset and reinstall of edge I am still not having any luck. Pressed the reset button on the back for about 30 seconds, gave it around 10 mins, went through the initial setup screen on the router and still no luck
Message 15 of 19
Sureshot08
Looks like an issue specifically with the netgear router. I also have a net duma r1 router running the 3.0.207 version and everything is working as intended on my r1
Message 16 of 19
Netduma-Fraser
NetDuma Partner
There may be an issue in the boot process so reinstall the firmware using the TFTP method https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-M... that will bypass the boot process then after its had time to install do a factory reset for the cleanest installation possible
Message 17 of 19
Sureshot08
When I turn the router off for 10 seconds the power led will come on as orange but not blink. When I run the command it takes a minute and tells me connect request failed
Message 18 of 19
Netduma-Fraser
NetDuma Partner
Get to the point where it tells you to unplug the power, do that, then hold the reset button, plug in the power and only let go of reset when you see it flash 10 times, then continue with the guide and see if that works.
Message 19 of 19
Discussion stats
  • 18 replies
  • 1460 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
