bebo131
Mar 13, 2021Aspirant
XR300 Disconnects every 2 hours
My router XR300 keeps disconnecting/dropping me from any game that needs a constant connection like Call of Duty Modern warfare or Warzone every 2 hours consistently. I don't get dropped from every other application that require a internet connection loses it's ability to connect to the internet. This includes discord, web pages, streaming show and anything else not in the game. Has anyone come accross a fix that is actually a viable option. I hate to think that I bought a router that was this expensive and netgear can't even come up with a firmware update solution. everything in my computer is updated and working 100%
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message. - Netduma-FraserNetDuma PartnerDoes it restore the connection immediately after the drop? Are you using the Geo-Filter? If so disable that, does the issue continue?
- bebo131Aspirant
i dont know how to disable the Geo-Filter i m going to add some pictures this just happened today after 2 hours it kick me out, live stream was running and other online applications as well i contact battle.net and there is no problems with the game in my pc or the servers.The problem is the router that after 2 hours kicks me out of the online gaming
- Netduma-LiamNetDuma Partner
In your browser, go to 192.168.1.1 or routerlogin.net and login to the DumaOS interface. In here you can go to Geo-filter and select 'Specatator mode' for you PC.
Hi All
I am on PC and experienced these 'disconnected from server' every 2 hours -ish since the beginning of Warzone amongst many other of their Warzone glitches. Over many months (possibly a year) I have tried so many different declared fixes across the web with all being unsuccessfull....until now.
Happy to report I have now jammed Warzone 24 hours without one disconnection :)
I think I found a solution and this may work for many - not all. This disconnect from server error BLZBNTBGS000003F8 appears to have more than one cause for these disconnections, across the platforms. All evidence is pointing to their servers and program (Blizzard) etc
Here is what I tried previously:
1. Update all your PC software
2. Made sure Im always plugged in via Lan Cable
3. Port forwarded all ports according to Activision etc
https://support.activision.com/articles/ports-used-for-call-of-duty-games
4. Added ports and Warzone related programs into Firewall -inbound and outbound
5. I have always used Google DNS and made sure this was on my static IP
6. Manually updated my Router Software
7. Turned on Dynamic QoS (via router settings)
8. Downloaded EXITLAG program to see if this corrected the error. (This didn't work but I may have experienced better ping in-game :))
Here is my fix!
Step 1: Close your Blizzard Program/Launcher then proceed to delete the Battle.net folder
Step 2: Load Blizzard program and then log out and close the Blizzard Program
Step 3: Open Blizzard program and at the login - click the settings and change login region to Asia/America (where ever you are) ...then login!
Step 4: Once logged in, change region inside of blizzard program to Asia/America (if not already on the same)
Step 5: Load Warzone
Once Warzone has loaded switch back to the Blizzard Program and log out. Then close the Blizzard program while Warzone is running.
Go back to Warzone and Enjoy without being disconnected.
-Let me know how you goI would like to state, Activision and any related party have NOT been helpful.
PC with nighthawk router R7000P
Windows 10
Regards
Van_Damage_NZ_
- DearGeoTutorI play on my xbox and only on my Xbox. And I get the same error “disconnected from the wired network” then it saids “connected to the wired network “ while playing MWF. I reset, soft reset and updated my router. I’ve even changed my xbox, my isp from Xfinty to Frontier FiberOptic. And I still get the same error. Please help.
Do you own your own place or rent?
Ive had a similar issue in an older place I rented. I went through ISP. router/s hours making changes to internal settings and even spoke with a few technicians who checked the connections from footpath and in house.
After 6 months and multiple complaints they eventually replaced the connection (in the house) and the instant disconnections and re-connections immediatly stopped - it was an older connection
This was random behaviour for the device and we still cannot explain how and why this occured. It was chalked down to the "older" connection points
