- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello, my lease renews every 24 hours, at which time I lose connection for about 30 seconds even though my ip never changes. Is there a resolution for this issue? My other Nighthawk R7000 router doesn't have this problem, lease renews without any connection loss.
Firmware versions I have tried:
XR500-V2.3.2.40.img
XR500-V2.3.2.56.img
XR500-V2.3.2.104-DumaOS3.0-Beta.img
Currently running: 2.3.2.40
Setting a static ip is not an option.
Thanks,
Jordan
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Reporting back as I said I would, downgrading to firmware version 2.3.2.22 fixed my DHCP lease renewal connection drop issue for anyone that's having the same issue I recommend trying this.
Cheers
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: XR500 DHCP Lease renewal causes connection drop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The connection drop problem is with the WAN, not the LAN. The drop happens when the dhcp lease renews with my ISP. I still have connections with my NAS via LAN when this happens so it's a WAN issue.
My ISP doesn't allow me to set a static ip on the WAN without paying for a business line.
Plus, setting a static IP isn't a fix, It's a workaround. I shouldn't have to do that. Dropping the connection everytime the WAN lease is renewed is ludicrous.
Thanks for the link to that thread, I'll try to provide some logs. I've searched the forums and see threads going back two years for this problem. They are just now trying to address this major issue? /rolls eyes
Jordan
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It's a pure modem, I don't have the option to do that.
I could go to walmart and buy a $30 router, set a static ip to this piece of **bleep** $300 dollar router so it can function.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I read on another thread that everything below firmware 2.3.2.22 doesn't have this issue so giving 2.3.2.22 a try now, it's been three days and haven't had any connection drops when the dhcp lease is renewed. I'll report back after week if it resolved the problem. This is still not a fix though, I'm running older firmware that doesn't have vulnerability fixes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for the response, instead of looking at user data, they may want to look at what was changed from 2.3.2.22 to 2.3.2.32. User data from alot of the later versions may not be so helpful due to the amount of changes made beyond that version. Whatever this bug is happened with the .32 update and propagated all the way up through beta.
.22 to .32 is an incremental update, it's probably something small that happened.
That's my 2 cents, thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks, if you hear of a resolution I would appreciate a response to this thread. I would like to get off of this firmware version at some point.
I appreciate you responding and escalating the issue.
-Jordan
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
User | Count |
11 | |
4 | |
3 | |
2 | |
2 |
