Stykee
Oct 15, 2018Guide
XR500 Internet speed Problem
So i bought mt XR500 router just a week ago, and i started to notice that am getting very slow internet speed compare to my ISP router?!?!
I dont know what the problem is i tried everything turning the Anti buffer to (never), all i get is just a little boost of speed. I mess with the Bandwidth still no change. I honestly dont know what the problem is, but when i use my ISP router i get the speed that im paying for.
XR500 Router SpeedISP Router Speed.
Can anyone help me with this problem.
- Netduma-FraserNetDuma PartnerDisable QoS completely from Anti-Bufferbloats options, do you receive full speed then? I'm assuming these are wired and not wireless speed tests?
Yes their both wired connection. and yes ive already disable the Anti-bufferbloat, i set it to (Never).
Nvm you just solved my problem lol. What does Disabling the QoS do anyway?
Speed with QoS full disable.Fully Disabling QoS seem to fix my problem
