Orbi WiFi 7 RBE973
Reply
XR500 Port Forwarding
rothnd
Howdy! I am stumped after being at this most of a week. I am trying to open a couple ports through my Nighthawk XR500 V2.3.2.134 running DumaOS. When I use the grc Shield's Up scanner, it shows all (every one) of my ports as 'Stealth' even though I've 'opened' in the router. For context without specifics I have a Mac mini running macOS 14.5 ethernet connected to the XR500. I assigned the Mac a static IP. In Port Forwarding of the router, I added custom service both udp/tcp on port xxxxx for that IP. I've rebooted everything in sequence. Yesterday I spoke with Spectrum to ask about a double NAT issue (I only have a modem from them not a combo) and they said I'd have to reach out to the router community. Any thoughts?
I've managed to use my service if I'm running behind a VPN with port forwarding but I can't get anything if I don't run the VPN and I'd rather not have the VPN in front of the service.
Any help would be greatly appreciated!
Message 1 of 16
Accepted Solutions
Guru
Re: XR500 Port Forwarding
It's either or. uPnP works in most configurations. Specialized configurations, needs to be disabled.
Message 10 of 16
All Replies
rothnd
Just to add some information/confusion. Attached images. Port showing open in my test application though on canyouseeme it's error closed and on grc it's stealth. Also router view for port forward on internal IP.
Message 2 of 16
rothnd
Message 3 of 16
rothnd
Message 4 of 16
rothnd
Quick update - did a bunch of troubleshooting today with some techies’ help. Things learned - I’m not behind CG NAT/double NAT. The problem appears to be with the XR500. Some zone/security/something or other is not allowing the opening of ports on my network. Please help if you can!
Message 5 of 16
Guru
Is uPnP disabled if you have any PF configurations setup?
Message 6 of 16
rothnd
UPnP is currently enabled and attached to a different service & port from what I’m working on currently. Modem picture attached.
Message 7 of 16
Guru
uPnP needs to be disabled if you have any PF configurations setup.
Message 8 of 16
rothnd
Seriously?? I thought those could work in concert…. Ok. I’ll test that here shortly.
Message 9 of 16
Guru
Message 10 of 16
rothnd
*** have got to be ******* KIDDING me!! All that because of UPnP.... First test says THANK YOU THANK YOU. While I have you, one stupid question - something like iCloud Private Relay - will that inherently block PF due to mismatch WAN? Thanks again!
Message 11 of 16
Guru
Anything is possible. Something to test with it enabled or disabled. I've keep iCloud enabled for most of my Apple devices, I only disable WIFI Private IP address on Apple devices while at home. Same goes for any Android devices. Seems like these mfrs along with Windows now have MAC Address randomizers enabled by default which seems to cause odd problems for users at home. IMO, this is not needed while at home. Out side and travelling yes have it enabled.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 12 of 16
rothnd
Well that seems to have fixed the PF issue. Thank you so much!
On to the next thing if you would - Hybrid VPN. I have uploaded my VPN config file (using Torguard). The router says it connects. whatismyip changes the external ip. However, I can't seem to figure out how to say do this, not that. I am testing running the Hybrid while allowing service on a forwarded port 50268. The port shows open when the Hybrid is not engaged. But closed on both VPN IP/Normal WAN when engaged.
Can you help me separate my traffic please?
Message 13 of 16
Guru
Not well experienced with Hybrid VPN. There maybe others that are and hope they post. Look up any VPN information here to start I guess.
Message 14 of 16
rothnd
Ok thank you!
Message 15 of 16
Guru
Message 16 of 16
Discussion stats
  • 15 replies
  • 3496 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
