× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 QoS error: device not found
David84
Hello. I updated my xr500 router with firmware V2.3.2.144, I reset it and after setting everything in Qos a popup comes out with this "error: device not found". I tried to install other firmware, new version of Netduma 3, factory reset done 5 times but it didn't count to anything. You can help me? currently i have installed version V2.3.2.120 but it doesn't work with any version (installed firmware and done factory reset every time)
I have a pppoe fiber connection from Italy
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: XR500 QoS error: device not found
Downgrade to a previous firmware, do a factory reset from the interface, then re-upgrade again please and it should be working
Message 2 of 4
David84
I had already tried but it doesn't work.
luckily I just solved it like this:
factory reset
firmware installation .114
factory reset
I turned on all devices (including ps5)
router setup wizard.
now it works correctly.
Maybe it gave an error because the ps5 console was not turned on at the time of reset?
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Yes that's possible, glad to hear you got it sorted, thanks for posting the solution!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1966 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
