- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
XR500 - VLAN tagging making wifi devices unable to communicate?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 - VLAN tagging making wifi devices unable to communicate?
Wow, that was quick!
Thank you.
So I'm going to buy another router then ...
Any suggestions?
OP mentioned he got an Asus RT-AC88U ... looks ok from what I can tell.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Our office shut down due to COVID so I never sourced a replacement router. But I haven't come across this problem on other routers, so hopefully you'll be fine with whatever you get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pretty sure it was tested above with no avail. Would be great if you guys could fix the VLAN and also add more options to add more DHCP serves for the VLAN's as well. Would make the router perfect for me and wouldn't have to swap it for something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Receive today... and go back to Amazon after discover that issue...
last BETA update doesnt work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
J'ai un synology, une shield, un pont hue en ethernet, et le reste est en sans fil.
Je suis chez orange en opérateur, le xr500 est directement compatible avec eux.. À ce que il paraît.
J'ai passé l'après midi dessus... Impossible depuis le WiFi d'atteindre mon serveur plex hébergé sur mon syno depuis une page Web. Ping OK pourtant...
Multiple RaZ et puis j'ai découvert que ya du monde depuis 1an qui galère avec ce problème...
La version proposé par Fraser n'arrange pas le souci.
Bref, mauvaise expérience mais vite rétabli en le remettant dans la boîte et en utilisant la box opérateur..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know this is 4 years later, but the fix for me was the following
Under Vlan/Bridge Settings which is under advanced.
Go to By VLAN tag group and create a new group called "LAN" in the vlan ID box call it vlan 1 and select up to 3 Wired and 2 wireless (keeping one Wired port free)
After doing this click apply
Next and this is the most important step under where you see this new group. Make sure where it says "Enable" , Untick it!
For some reason what this does it keeps your one wired and one WAN as the one single vlan ID you require for internet.
And then it sets the rest of your wireless and wired as vlan 0, making communication work again across the different ways of communication (wired, wireless, 2.4/5ghz)
I'm also on the beta version XR500 V2.3.2.134-dumaos33-rc14
- « Previous
- Next »
