Rosse
Nov 16, 2018Aspirant
XR500 antennas
Hi all.
Just bought a XR500, which has 4 antennas.
2 on the back, both marked “1”, and antenna marked “2” on the left and “3” on the right.
The number ”3” antenna does not fit into the right slot (Which is market 3 as well), but fits into the left slot 2.
The number “2” antenna fit into both the left port 2 as supposed to, as well as into port 3 on the right side of the router.
Anyone knowing if the antenna function/length are the same for the number 2 and 3 antenna?
I plan to go to my dealer to have it exchanged, but I’m afraid that he just tells to swop the number 2 and 3 antenna, but if this is not correct, I will be sure to tell him.
Thanks.
Thanks.
- Netduma-FraserNetDuma PartnerThe numbers should match up so odd that they don't. However as far as I am aware they are all the same length/have the same function so in theory it shouldn't matter too much which one they're connected to.
- RosseAspirantThanks a lot for the quick reply.
I agree. The external dimensions are the same of all 4 antennas.
But if it is just a matter of design, or actually the antenna inside the plastic protection on the antenna, that’s what I’m most curious about...- Netduma-FraserNetDuma PartnerI think the antennas were just misnamed on your router for some reason, won't affect performance in any way
