× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
XR500 no wifi devices will connect to internet
xlr8r
Guide
okay
so just bought eth Xr500 and set up everything as per my old R7000
only thing is, NONE of my wireless devices will connect to the internet ????????????
pulling my hair out right now .....
all wireless devices show offline in the Xr500 Device Manager
also noticed, alot of devices i "named" are not showing their new names across the menu's...?
updated to latest firmware , same thing
HELP!!!!!
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 6
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: XR500 no wifi devices will connect to internet
Hello, you just made a post on our forum, here is what I said there: Factory reset the router from Settings > Administration > Back up settings and click erase. This should resolve the WiFi issue. Are they all connected but just no internet access?
Did you click Update on the device panel after you had given it a name?
Message 2 of 6
All Replies
Netduma-Fraser
NetDuma Partner
Message 2 of 6
Djimi
Guide
I can't get the xr500 to work. Says connected but no Internet. Have reset the router and every time I put in my ISP pppoe settings. (username & password from plusnet) I just get this message. Help me please.
Message 3 of 6
Netduma-Fraser
NetDuma Partner
Djimi, there is no need to make multiple posts. I have already responded to you on the Netduma & Netgear forum.
I would highly recommend calling Netgears 24/7 English Support Line as they should very quickly be able to resolve the issue you're having. They are much more familiar with the Settings as they created it. Sign in here: http://support.netgear.com/and you should get a number to call.
Message 4 of 6
Djimi
Guide
Sorry. I thought their would be different people on each forum. And I'm pretty desperate to sort this. Been trying for 2 days and still can't do it. This is on top of having troubles with the R1 & Plusnet for the best part of a year.
Message 5 of 6
Netduma-Fraser
NetDuma Partner
As I mentioned if you call the support line you'll get it resolved very quickly!
Message 6 of 6
Discussion stats
  • 5 replies
  • 8766 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
