- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: XR700 Constant Issues with DHCP
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you. The OpenDHCP box I stood up is doing the trick quite nicely for now. I'm will be pretty busy for the next few weeks, so if I see a hotfix of a new OS I will try to test it if I have time. Otherwise it might be early December before I can shut my network down again and see if the router actually works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@militant_jawa Thank you! A recommendation on a open dhcp server. I'll do that one tomorrow.
@Netduma-Fraser thank you. If you are near the bracknell office in UK, I'll owe you a pint when we're out of lockdown. Netgear is a partner of the company I work for so I'm in the offices occasionally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
http://dhcpserver.sourceforge.net/
Super easy.
- Install
- Modify the config file with scope(s); add static reservations if needed
- Restart service
Make sure your computer is set to not sleep, suspend, or in other ways turn off or the leases can't renew when they expire.
Cheers!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
🎱 🍆 🎱 It’s the least you could do for us customers they got hustled
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Best thing you can do if file a complaint here:
https://www.bbb.org/us/ca/san-jose/profile/internet-service/netgear-inc-1216-210357
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I upgraded to .36 and the system did its thing where my wireless devices won't connect. Rebooting via the OS did nothing. Unpulgging it immediatly plugging it back in did nothing. Master resetting the router did nothing. I let it sit for about 15 minutes unplugged and that did the trick. :-(
Has anyone had any joy with the beta firmware and these issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'll give that a try when it inevitably happens again in a month or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks, let us know how you get on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well, I asked if anyone had any success using it and the response was to turn off wifi, reboot and turn it back on.
I dont really want to use a beta that has other issues as you can see in the related forum post, compounding my issue. It is also running an older verison of firmware with who knows what security isuses since Netgear's documentation says nothing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If there is anything I can do to help let me know . The issue used to happen once every few months, but has happened twice in December now so I'd really like to have this resolved.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Plugin a USB device to DUT (router). Open debug page: http://192.168.1.1/debug.htm
Select the checkbox “Enable WAN/LAN Packet Capture”.
Choose “USB Device” in store location.
Click "Start Capture" button.
Once issue occurs, press the Button “Save debug log”.
Send the log to us. (@TimChang)
Please make sure in the capture file in \\192.168.1.1\USB_Storage\Capture, there are lan.pcap and wan.pcap file inside.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Netduma-Fraser wrote:
@SillyMoa Netgear dev has provided a debug firmware for the 500 with instructions on what to capture. I don't think you specifically need that firmware to capture what is needed so if you can try doing this:
Alright... so the issue is currently happening.
When I enable WAN/LAN capture it disables itself on reboot. I'm also not seeing the lan.pcap or wan.pcap files in here.
What am I doing wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
An update, I remembered I got ProSupport and gave them a call. While I was waiting for them I was just poking around and seeing what I might have done to cause an issue. It might be coincidental but, I reset the router and everything worked using the default settings. I changed the SSIDs and password and boom. IPs stopped assigning to all of my wireless devices. I changed them back to the defaults and it started working again. After a bit more messing around, every change I made didn't cause an issue except changing the SSID AND the password. Changing the SSID and leaving the default passwords worked, changing the passwords but using the original SSIDs worked. It is very strange. The support rep I talked to didn't seem too surprised when I was talking to her about my issues. After a few minutes of trying some things she decided I should just RMA my router. Thats all done and I shall be getting a XR1000 instead of the XR700. Hopefully it is a better experience than my XR700.
If you still want them, I think I got the logs and files before I called support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If only they would RMA mine as well. Still major issues and as i use this for WFH i cant risk using a BETA that may cause me other issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Eidolan if you can provide the information above NG can work on a fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi
Im out and about currently dealing with some stuff.
In short i havent tried the leaving the SSID as standard and the password ass is. I always reconfigure ssid and password.
What happens if i reset my router is:
Change SSID
Change Password
Set a reduced DHCP range for 50-199
Previous devices with saved credentials will try and reconnect.
Anything with static IP will be succesful in connecting to the wifi
Some of the DHCP devices will be succesful to connect and recieve an ip address.
Other will say cannot get ip address.
When i looked at the log it shows trying to allocate IP address. allocated IP address. then re tries to allocate the same address to the same MAC.
I have now been using a standalone DHCP server and i have now no issues on connecting previously configured devices, static devices or dhcp devices.
My network is temporarily stable.
My previous comment about RMA, is that if the XR1000 is a working and usable device a XR700 replacement would be much appreciated
User | Count |
11 | |
5 | |
3 | |
2 | |
2 |
