- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr500 not connect some devices to internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the last week 2 devices no longer get the internet, one that is connect to wifi says it is offline and the other is connected through a switch via an ethernet cable. Both an be found connected to the router but they for some reason do not connect to the intnert, I have 1 gig speed and my other devices work fine. I tried having thei internet company replae the cable go into my house, power cycles, and what not, nothing fixes the issue, also tried disabling QoS and no change.
Anyone can help?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Finally sloved. I called Netgear since my replacement router is uder warrenty and basically had to hardcode the primary and second DNS servers as the one provided was too congeteted. Now everything is back and running.
Greg
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 not connect some devices to internet
Hey!
What types of devices are they exactly?
Are they appearing in device manager in DumaOS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes it shows up in Dumas, One is a nest that i may have working again by doing numerous resest, connecting to my cellphone and then after setup of the nest when I disconnected the phone it connected to my wifi and had internet. Odd. The other is DirectTV box,might be the box, but I am more worried as my personal computer also couldn't connect to the internet but is working now.
Is there anything I can check to prevent in the future?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nest says it is offline again, 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think there is any manual settings except port forward for my ps4, are you saying to port forward on these devices and give them a static IP? Because they do show up in Dumas OS so they are connected to the router but not being supplied a connection.
greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another update both devices show up on my dumas OS and it seems that the nest says it is connected but when I got to the app it is offline and directTV won't access internet even when i plug it into my modem directly so I think it is two different issues.
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I meant to add for a wifi device, is it still under lan setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Figured out how to set an staic IP and it didn't fix it at all. Same issue. Does that mean it is the device?
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't connect the nest to the modem directly as it uses wifi, it works when i connect it to my phone's hotspot. All my other wifi devices work. I have a ARRIS SURFboard SB8200 for the modem.
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Created a guest network and it still says offline after connecting to the router and I can see the device on the guest network as well.
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
turned off smart connect and when I connect to the 2ghz network, there is no change, still offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unless there was a recent firmware update, I haven;t done anything to my setup recently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried it wirelessly with my hotspot and the nest worked but the DirectTV didn't work at all. They replaced the box for DirectTv and still nothing. He said for DirectTv it could be a software issue as their was a recent software update for DirectTv. But it gets alll the ip, dns and network info.. I am getting a new nest display sent but now not very confident it will fix it :(.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Saying that, in WAN Settings toggle IGMP Proxying, if that doesn't work switch NAT to Open.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No change will update if the replacement works or not.
