Reply
Xr700 connection drop off / disconnects
Vazuh
Having the same issue as everybody else!
The newest firmware causes my connection to drop every 20/30 seconds which causes me to get connection interrupted in games.
As soon as I change my firmware back to the original firmware the router came with all of the connection drop offs stop and I have a normal constant connection.
Is there a firmware that can help with this?
When is the firmware going to be updated?
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 22
Accepted Solutions
Christian_R
NETGEAR Employee Retired
Re: Xr700 connection drop off / disconnects
Hello Vazuh - I have sent you a message. Please check your inbox.
~Christian
Message 4 of 22
All Replies
Netduma-Fraser
NetDuma Partner
I'd suggest you stay on the one you're using at the moment as its stable for you. The team are looking into it so I'm sure they'll provide a fix as soon as they can.
Message 2 of 22
Vazuh
I’ve been told to post on here as there is a beta firmware that will fix the problems as well as having the new features that I’m missing?
Message 3 of 22
Christian_R
~Christian
Message 4 of 22
N4zer0
Same issue but fix by purchasing a sfp modual connecting that to my virgin router , but I really shouldn’t be purchasing another bit of kit to get a £450 router to work on the latest firmware !!!!
Message 5 of 22
Netduma-Fraser
NetDuma Partner
Glad to hear that resolved your issue. It should be fixable by firmware, perhaps @Christian_R can help.
Message 6 of 22
Christian_R
Hi N4zer0 - We have a beta firmware available for the XR700 that may resolve your issue. If you're interested, please send me a message.
~Christian
Message 7 of 22
N4zer0
Hi yes that would be great thanks
Message 8 of 22
Christian_R
Hi N4zer0 - Thanks for reaching out. I have sent you a response.
~Christian
Message 9 of 22
LegendaryJMac
I have the latest firmware, version 1.0.1.8. As soon as I updated to this version, I immediately noticed my wireless connections (Nest cams, iPads, etc) were no longer working. I noticed my router was giving out 192.168.1.XXX IP addresses. Prior to the update, I was using my own 192.168.0.XXX IP addresses. After further trial and error, I came to the following conclusion that ensured all 60+ nodes on my home network were back online: I reset the router with the same firmware version (1.0.1.8) installed and utilized the default 182.168.1.XXX IP addresses. My router is set to DHCP server and it works flawlessly again. No static IPs were setup.
Message 10 of 22
LegendaryJMac
Correction: I reset the router with the same firmware version (1.0.1.8) installed and utilized the default 192.168.1.XXX IP addresses.
Message 11 of 22
Guru
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 12 of 22
Netduma-Fraser
NetDuma Partner
Hi Legendary, the original firmware should resolve the issue you're having but also @Christian_R may be able to provide you with a beta firmware that can help.
Message 13 of 22
maidintaiwan
please send me a beta firmware as well.....
Message 14 of 22
Netduma-Fraser
NetDuma Partner
I've messaged Christian on your behalf maidintaiwan for the firmware.
Message 15 of 22
Guru
New FW available:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-XR700-v1-0-1-10-Firmware-Available...
Message 16 of 22
maidintaiwan
I am still having the same problem after updated to 1.0.1.10....
and it seems like it got disconnected more frequently than 1.0.1.8
I guess I will try to flash it to 1.0.0.20 for now...
Message 17 of 22
Netduma_Jack
NetDuma Partner
OK, let us know how you get on.
Message 18 of 22
Danny80916
Luminary
Hey man ask christian if she can get you to a level 3 or 2 tech with your problem.
Message 19 of 22
maidintaiwan
Before I switch my router to XR700, I was using xr500 and everything was fine....
But before xr500... I use R9000 ....I think it had similar problem....WAN got disconnected randomly.... Does it have anything to do with the IP? Xr700 automatically switch my IP to 10.0.0.1 but I changed it to 192.168.0.1.... will it cause all these problems?
Message 20 of 22
Danny80916
Luminary
I dont know i never had a problem with wan but i use a 10gb sfp device in that slot
Message 21 of 22
Netduma-Fraser
NetDuma Partner
maid that won't have caused the issue, that's a standard setting on the router.
Message 22 of 22
Discussion stats
  • 21 replies
  • 4335 views
  • 5 kudos
  • 9 in conversation
Announcements
