BIC2's avatar
BIC2
Tutor
Nov 28, 2020
New Install Won't Connect to Internet
Actually an RAX45 Nighthawk AX6 from Costco, but not listed on the drop down menu. Have Spectrum cable ISP which is DHCP Dynamic IP as far as I know. Everything on router lights up OK. Rebooted DOCSIS 3.1 Modem/Voice equipment, waited for full boot, then plugged in router. Tried this a few times. The Nighthawk app says cables good but no Internet.
I can go back to the Spectrum router, still works. I have also tried a tp-link TL-WR940N, an inexpensive router which is several years old and that works with no configuration--just plug & play. Thanks.
  • michaelkenward's avatar
    michaelkenward
    BIC2 wrote:
    Rebooted DOCSIS 3.1 Modem/Voice equipment..
    What is it? Make and model?
    Remember, when you replace one bit of your network, you may have to reset everything in the chain, including the modem.
    These things communicate during the set up process and adapt their settings accordingly.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it connect.
    • Turn on computers and rest of network.
    • BIC2's avatar
      BIC2
      Tutor
      michaelkenward
      Modem is Spectrum Model E31T2V1.  I have gone through the sequential bootup between modem and router as you have described.  I did not turn off any other devices.  Not sure I can even remember every IoT device I have, certainly there are dozens.
      I get the "no Internet " message from the Nighthawk app.  I'll try again with reboot of Android phone and computers.  Spectrum has replaced the Sagemcom router a few times and as I mentioned, I can insert an old tp-link router with no problem.  For all these router replacements, I only do the modem/router boot sequence, I've never re-booted any other device.  Thanks.
        michaelkenward
         It looks like  a basic cable modem, but there seems to be some confusion out there.
  • Identical experience: no Internet during initial setup but all lights white. Very frustrating. Have been unable to resolve after 2 attempts and reverted to original setup. Have rebooted in sequence. Inserting another router and connection works. Reverting to original router and connection works. Connecting exact cable to WAN port and get the error. Only thing left to try is connecting just the Internet cable first before any other devices. Will see. Else I’ll have to call for support which makes me cringe.
      michaelkenward
      Possibly. But that could be caused by many things and we know nothing about your equipment or what is happening at your end.
      It is a bad idea, and against the rules, to hitch a ride on an old conversation that is now near on two years old and may well have nothing to do with your issue.
      There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
      If you do want help with your problem, check previous stuff that may be related then start your own discussion.
      If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.
      Subject (Include model number and brief summary)
      Model (Recommended - Helps the community give the best answers)
      Body (Include additional detail including model version, firmware, OS and environment where relevant.)
      They are there for a good reason.
