JohnD2d
Jun 01, 2022Aspirant
ax12 rax120 apps only not syncing with servers
outlook app and vodafone app and others not syncing with their servers
they will work over 4g data but not wifi in this case im using samsunf galaxy a52s 5g and another android phone.
funny thing is i will receive emails over wifi through gmail app but not for outlook app
surfing and streaming on other devices is fine but theres a question mark on two android phones using wifi in the house.
Has anybody come across the strange business?
1. you have the rax120. what firmware is on it?
2. what modem/gateway is it connected to?
3. are you using the isp's dns servers or custom ones?
4. is ipv6 enabled?
- JohnD2dAspirant
Hi
latest firmware installed for ax12 rax12o auto update then manual flash using latest firmware
connected wired to old d7000v2 in modem only mode works fine
dns set to primary 8888 secondary 8844 recommended by isp and netgear
ipv6 disabled
just apps problem on two android phones samsung
its a weird one.
So you're using an old D7000 as modem? Is that correct? Or what modem are you using?
And what actual version of firmware are you on? "the latest" isn't always, it changes, or the latest might not always be the best. Its why we ask.
Why did you disable ipv6? Some newer services are defaulting to that from the start.
did you try a different dns server than googles?
