Orbi WiFi 7 RBE973
Reply
5g internet won’t connect
Carri1221
Follower
My 5g won’t connect, everything shows online however when trying to connect to a console it shows a message that it cannot connect to the router. When I called tech support the claimed that I needed to purchase firewall protection, but when then also tell me that I need to also purchase “support” in order for them to help me.
Message 1 of 4
Guru
Re: 5g internet won’t connect
1. what router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. do wired devices work?
5. do 2.4ghz devices work?
6. did something change? is this a new purchase?
Message 2 of 4
schumaku
Guru
Do not - never - Google or use any other search engine for locating support, for whatever product. To many actors of the spam and scam mafia out there. You will loose money  questionable fake support action and service.
Message 3 of 4
That wasn't Netgear that you talked to.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 739 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
