Dancolt1234
Apr 19, 2021Follower
63A7OC7XA5313 mesh nighthawk
Hi I bought this hooked it all up and it says I can't connect to internet . Is this because my home router is still hooked up?
I see my original router and the nighthawk. When I click on nighthawk it says connected but can't connect to internet.
Please help
Please help
What system did you actual buy? A model number helps.
Cascading routers isn't a recipe for a working network. It causes a double nat.
What is Double NAT? | Answer | NETGEAR Support
how do you actually have your network laid out?
> [...] I bought this hooked it all up [...]
Swell. What, exactly, did you "hook up" to what, exactly? (Hint: If
a device has different types of ports, then "connected to device" is not
enough detail.)> [...] and it says I can't connect to internet . [...]
"it"?
> [...] Is this because my home router is still hooked up? [...]
Has your (unspecified) "my home router" a maker and model number?
What, exactly, did you "hook up" to what, exactly?Has your (unspecified) "the nighthawk" a model number? Look for
"Model" on the product label.> [...] When I click on nighthawk [...]
Does that mean that you're using some Nighthawk app? I'd suggest
using a web browser, instead.You might start with an oft-neglected resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read?
