Orbi WiFi 7 RBE973
Reply
Already registered
gmonkeyq
Already registered
My product says it was already registered. Why can't I re-register it in my name, I bought it from a guy on LetGo, if they're allowed to sell them then i should be allowed to reregister it.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 6
Accepted Solutions
duckware
Prodigy
Re: Already registered
Of course.  http to the address listed on the bottom of the router and use the username/password listed there.
If you can't get in, do a factory reset (tiny button hole on bottom/back of router) and that will/should reset things to what is listed on the label on the bottom of the router.
Message 5 of 6
All Replies
duckware
Prodigy
If it was sold as "new" -- return it, it is not new.  If it was sold as used, you can't register it.
Message 2 of 6
gmonkeyq
Without it being registered can I still change its name and password? If so, how?
Message 3 of 6
gmonkeyq
He said it was new and unopened, but it still works very good, but Can I change the name of the network and the password without it being registered?
Message 4 of 6
duckware
Prodigy
Message 5 of 6
Spot on there, and to deal with "already registered" issue – that's the third today – you probably need divine intervention, or at least help from one of the Netgear support people.
Here's how it worked in the past:
Solved: Cant register product (AC1200-R6220) WiFi router) - NETGEAR Communities
Hope it works.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 12594 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
