Orbi WiFi 7 RBE973
Reply
Blocking a specific device on a Nighthawk X6
Acann
I am trying to block a specific device from connecting to my Nighthawk router. I can access the router by using 192.168.1.1 to log in. I can see the device I am trying to block. I went to advanced then security then clicked on access control, it does not display any of the devices connected to my router. This is what happens.
I have checked the firmware on my router and it is up to date.  I tried accessing my router using chrome and MS Edge. Same result for both.
Any assistance is greatly appreciated.
Message 1 of 9
Guru
Re: Blocking a specific device on a Nighthawk X6
Do you have Circle or Smart Parental controls enabled in the Nighthawk app?
FW is behind.
https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/New-R8000-Firmware-Version-1-0-4-88-Re...
Message 2 of 9
Acann
I updated the firmware to V1.0.4.88_10.1.88.
I do not have acircle or smart parent.
I tried to access the specific devices after updating the firmware. I get the same emoji that says: 192.168.1.1 didn't send any data".
Message 3 of 9
Guru
Try a factory reset and setup from scratch after FW was updated?
Message 4 of 9
Acann
I got the same message after I updated the firmware.
I did not do a factory reset.
Message 5 of 9
Guru
Lets give that a go then. Possible the web ui at this feature could be some bad state and needs cleared out.
Message 6 of 9
Guru
Do you know what device it is?
Message 7 of 9
Acann
The specific device doesn't matter because I can't get the access page on the router.
My thiughts...10 year old router.....might be time to invest in a new one.
Message 8 of 9
Guru
Maybe time.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1212 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
