Reply
Configuration Error when updating WiFi credentials/settings
msurls
App Version: 2.26.0.61
Firmware Version: V1.2.0.92_1.0.1
Model Number: R6900v2
I am getting a Configuration Error when updating WiFi credentials/settings.
I've tried rebooting the router, checked for updates, and have deleted and redownloaded the mobile app.
At some point I was able to change the password, but have not been able to change the network name or Security Method, which I want to make WPA/WPA2-Personal.
Please advise.
Message 1 of 6
Accepted Solutions
Guru
Re: Configuration Error when updating WiFi credentials/settings
They make USB to ethernet adapters that are cheap.
Connect the laptop to the SSID and PW of the router, then Log into the routers web page using Safari or Firefox browser at 192.168.1.1.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 6
All Replies
Guru
Use a wired PC and web browser to make the changes to the wifi settings on the router.
Message 2 of 6
msurls
Thanks for responding!
I don't have any wires that would connect my mac to the router.
And where would I go in my browser to update the WiFi settings?
Message 3 of 6
Guru
Message 4 of 6
msurls
Thanks. I was able login and update the setting in my browser without being wired.
Message 5 of 6
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 305 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
