netoperator's avatar
netoperator
Connected without internet
I have AC 4000 Nighthawk X65 model number R8000P. On my phone  it indicates that I am connected without internet. How do I correct this ? Thank you
  • plemans's avatar
    Did something change so you're getting this?
    Is this a new install?
    Any other devices having issues?
    What modem/gateway is the router connected to?
    • netoperator's avatar
      netoperator
      Nothing has changed because this is clean install on a new machine. No other devices has any issues. I use Verizon jet pack. The phone  is a Samsung with Verizon software.  I have Windows 11 and I update the machine every morining. Likewise I get upadates as soon as available. Thank you.
      • FURRYe38's avatar
        Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
        Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
