alpinac2's avatar
alpinac2
Fehlendes Arlo-Menu nach Firmwareupdate / Missing Arlo-menu after firmware-update
Nach dem Firmwareupdate auf Version 1.0.7.2 fehlt das Arlo-Menu und die Kameras können nicht aufgerufen werden. Was kann man da tun?
After the firmware-update on Version 1.0.7.2 the Arlo-menu is missing as well as the cameras. What can one do here?
  • problem solevd, the reason were different versions (firmware and GUI language version)!
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi alpinac2,
      The v1.0.7.2 firmware has no Arlo feature. If you have an Arlo system, continue to use the beta firmware with Arlo support.
      JamesGL
      Community Team
    • JamesGL's avatar
      JamesGL
      Hi alpinac2,
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      JamesGL
      Community Team
