Orbi WiFi 7 RBE973
Reply
Firmware check error
Mckammer
Tutor
When I try to update my router firmware, I get a “firmware check error”.  I tried rebooting, but I still get the message
Message 1 of 8
Accepted Solutions
Mckammer
Tutor
Re: Firmware check error
Was trying to update via the app, but getting an error message. Had to use the directions for manual update and it worked. Still not sure why I got the error on the app, but will do manual updates from now on.
Message 8 of 8
All Replies
Guru
You didn't put much info like model number. You can do a manual update to the firmware if its strictly a router.
go to https://www.netgear.com/support/default.aspx
put in your model number. It'll have the current firmware version as well as a section with manuals that can walk you through how to manually update the device. Give this a shot.
Message 2 of 8
Mckammer
Tutor
Thanks,it is model R6400 router
Message 3 of 8
antinode
Guru
> When I try to update my router firmware, [...]
   "try" _how_, exactly?
> [...] it is model R6400 router
   Which one?
> [...] go to https://www.netgear.com/support/default.aspx
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads.  (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".)  Find the
kit(s).  Download the kit(s) you want.  Read the "Release Notes" file
for instructions.
Message 4 of 8
DarrenM
Sr. NETGEAR Moderator
Here is a link on how to update the firmware and a link to the latest firmware
https://kb.netgear.com/23960/How-do-I-manually-upgrade-firmware-to-my-NETGEAR-router
https://kb.netgear.com/000060487/R6400-Firmware-Version-1-0-1-46
DarrenM
Message 5 of 8
Mckammer
Tutor
Problem solved. Thanks to all.
Message 6 of 8
antinode
Guru
> Problem solved. [...]
   "solved" how?
   For the benefit of the next poor slob who stumbles onto this thread
looking for useful information, revealing your (embarrassing/stupid?)
blunder could be helpful.
Message 7 of 8
Mckammer
Tutor
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 36033 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
