aravapalliarun's avatar
Dec 22, 2020
Internet & WIFI lights not coming after R6350-AC1750 Smart WiFi Router Firmware updated to 1.1.0.78
Hi,
I have update my Netgear R6350-AC1750 Smart WiFi Router firmware from 1.1.0.76 to 1.1.0.78. After doing that, the Internet & WIFI lights not coming.
Could someone please help on this?
Thanks & Regards,
Arun Aravapalli
  • plemans's avatar
    What are all the lights doing? (blinking/solid/color)
    Are you able to access the router via the web interface if hardwired in?
    Have you tried a factory reset? Push and hold reset for 7-15 seconds while powered on.
    • aravapalliarun's avatar
      aravapalliarun
      Thanks for your response.
      Only Power light(Green) light is blinking and rest other lights not blinking.
      When I connect the internet cable to my laptop, internet is working. So no issues with the internet.
      I tried with reset option but there was no response from the device.
      • plemans's avatar
        If internet is working, are you able to log into the router using the gui?
        Are you able to ping it?
