Orbi WiFi 7 RBE973
Reply
Is the R7000 good enough for 200/12, possibly more?
Retired_Member
Not applicable
Hi,
So we're getting 200Mbs down and 12Mbs up from Virgin Media soon and are going to put the Super Hub into modem mode and connect our own router. Wireless isnt very imporant but we still want it to be good, will the R7000 be good enough for those currents speeds and also future speeds of around 500/30? Also, I see 1.0.5.70 is the lastest firmware, is there currently a newer one in testing? Or has support stopped for this device now.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 9
Accepted Solutions
jbernardo
Apprentice
Re: Is the R7000 good enough for 200/12, possibly more?
I have right now 200/20 (telenet cable in Belgium). The R7000 is giving me full speed on my Xperia Z2 tablet, over 5GHz, at least according to speedtest.net, so I'd say you'll be well served with it with your current connection. On the tests that I did with iperf I managed to get close to the theoretical speeds on 2.4GHz and 5GHz, so it should also handle your future speeds. Of course, it will depend on the size of your house, wall materials, neighbouring WiFi, etc.
As for the firmware, I was running the v1.0.6.28 beta for some time, and am now on the 1.0.6.54. If you don't have any arlo cameras, I'd recommend you to stay with 1.0.5 for now, as you won't gain much with the beta.
Message 2 of 9
All Replies
jbernardo
Apprentice
Message 2 of 9
mondenath
Prodigy
getting the wifi speed purely depends on the client. Throughput is main factor one can acheive upto 45% of the connection rate. So plan accordingly. WIth n 300 Mbps you cant get 200Mbps only close to 150Mbps.
But with ac 5GHz yes you can reach upto 400Mbps so 200 is easily achievable.
Message 3 of 9
microchip8
Master
I also run an R7000 on Telenet (Belgium) business abo 240/30. It has no issues reaching those and according to SNB review, it has one of the highest throughput (WAN -> LAN and LAN -> WAN) of any AC1900-class router
Message 4 of 9
The R7000 is good enough for your config.
Message 5 of 9
mbob4568
Guide
I have speeds of 230/23mb up using Time Warner Cable Max. My R 7000 has no problems at all with the stock firmware.
Message 6 of 9
So go for it! Give it a shot!
Message 7 of 9
Retired_Member
Not applicable
I see the R7800 is only £10 more than the R7000 on Amazon yet is far Superior
R7000 = £140
R7800 = £150
Message 8 of 9
So go for the R7800!!!
Enjoy!
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4636 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
