SamJr's avatar
SamJr
Model R9000 - Netgear Genie Software
I need to reinstall netgear genie on a new computer and i did not receive a cd/dvd when i purchased my router.  Where can I get a copy of Netgear Genie?  It does not show up on any of the software download sites.
  • michaelkenward's avatar
    michaelkenward
    Netgear is doing its best to hide the desktop genie. It recently dropped the software from the usual place.
    The latest sighting was here:
    genie Landing Page | Apps | Discover | Home | NETGEAR
    Get it while you can.
    • SamJr's avatar
      SamJr
      Went to the recommended site however there is no place to download the Netgear Genie software.  All this link points to are apps to load on mobile devices.  I need to install the software on a PC.
        michaelkenward
        I don't know what you clicked, but it goes to the software here.
        https://www.netgear.co.uk/home/discover/apps/genie.aspx
        Scroll to the bottom.
        Look for the link:
        DOWNLOAD PC
