Orbi WiFi 7 RBE973
Reply
Need help changing/moving my account/email address over to a newer one
crrr4
Hello,
I created my netgear account years ago using an old email address and would like to move my account over to the new email address/account if possible. I have looked through several forums and dont see really any resolution for this.
Message 1 of 10
Guru
Re: Need help changing/moving my account/email address over to a newer one
I believe you can change the email address by logging into the NG profile account and making changes there:
https://accounts.netgear.com/account
Or you'll need to contact NG support for account management help.
https://www.netgear.com/home/wifi/mesh/orbi/
https://my.netgear.com/support/contact.aspx
Message 2 of 10
crrr4
Unfortunately I don't see anywhere to update/change my email address going to https://accounts.netgear.com/. And I cant create a support ticket cause the support included with my router is expired.
Message 3 of 10
Guru
You'll need to contact NG support and have them help you then. Nothing we can do here in the forums.
Can send a forum moderator a message and see if they can help you out.
@DarrenM
Message 4 of 10
crrr4
I finally see the option now, not sure why it wasnt showing up previously, but now I have to delete the second account I created previously so I can change the email address. Is there a way to do this I dont see an option to delete your account?
Message 5 of 10
Where are you looking?
Message 6 of 10
crrr4
I was able to log into the nighthawk/netgear app on my phone under the account/email address I want to delete and there is an option to delete account. I did that but I am still unable to change my email address it says email address already in use. However I just realized that didnt delete the account, how do I close this account so I can modify my old account with the new ones email address?
Message 7 of 10
Registration for Anywhere Access is not always tied to the same email address as MyNetgear. Nor are they always locked to the same email address as this place.
Message 8 of 10
crrr4
Is there a way to delete my Netgear account so I can just update the email address on my old one?
Message 9 of 10
Dud you read this?
Re: Need help changing/moving my account/email add... - NETGEAR Communities
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1417 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
