ouadasa's avatar
ouadasa
Tutor
Jan 16, 2024
Negear R9000 , protocol 802.1Q
Hello , i would like to know if the R9000 has the 802.1Q protocol , if so ,how to active it to use it . Thanks
  • FURRYe38's avatar
    Check the user manual for VLAN information and support. Most routers only have VLAN support for ISP services.
    For LAN side VLAN, those are mostly kept to the LAN switch domain.
    • ouadasa's avatar
      ouadasa
      Tutor
      in fact, i want to connect my R9000 to my ISP's router (witch i convert to a bridge) , a priori i will need 802.1Q .
      • FURRYe38's avatar
        Ask the ISP if any VLAN configuration is needed.
