- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk X6 R8000 - Factory Reset - Serial Number Missing
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently inherited the Netgear Nighthawk X6 R8000 and its missing the label with all the information including the serial number.
I already hit the factory reset button and I am directly connected and tried to access the gateway 192.168.2.1.
I get the admin login screen, which I enter in the default admin password combo, then it asks for a Router Password Reset:
"We can help you reset your router's admin password. You need your routers serial number, which can be found on the router label. Enter your routers serial number in the field and click the Continue button."
Not sure how I can continue without the serial number as the label is not attached to the router.
Please help me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk X6 R8000 - Factory Reset - Serial Number Missing
Try a different browser. MS Edge, Firefox or Opera,
Be sure all browser caches are clear before the reset.
Enter the routers web page at 192.168.1.1 not 2.1 after the reset. Be sure the press the reset button for 10-15 seconds then release.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
After resetting the device 3 times. I am now able to get into the setup screen to continue the initial setup of the router.
This was a bit frustrating to say the least.
I am in the admin portal, question is where can I find the serial number in the admin portal?
I would like to not repeat the process the next time I need to run through a reset.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Walk thru the setup wizard and be sure to write down important information for safe keeping. The setup wizard will guide you thru and setup a log in PW for the admin log in.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SuperHyphen wrote:After resetting the device 3 times. I am now able to get into the setup screen to continue the initial setup of the router.
Thanks,
You can't.
Log in to your user interface using 192.168.1.1/hidden_info.htm. Note the underscore character between hidden and info. The serial number should be on the second line of the screen. The word serial did not make it cleanly through translation.
My setup: Comcast -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.70HF)
- Mark as New
- Bookmark
- Subscribe
- Permalink
As an addendum, if you install the Nighthawk mobile application, I use Android, and connect to your router you can get the serial number of your router. Go to Menu -> About and it will provide your router serial number.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
