Orbi WiFi 7 RBE973
Reply
Nighthawk X6 AC3200 Smart WiFi Router (R8000) DNS ISSUE
LeeGillie
My router firmware version is: V1.0.4.84_10.1.84
I am having intermittent issues with DNS. I see this in a web browser. When I first go to a site it displays not available. but then a couple of seconds later it displays. It appears the first failure is because of a site not found error. For sites I go to frequently they always come up quickly. My dns server for my windows 11 desktop is my Netgear Nighthawk X6 AC3200 Smart WiFi Router (R8000). IPCONFIG /ALL show "DNS Servers: 192.168.1.1" My desktop is direct wired to it. I have tried 2 different DNS settings on the router, but it seems to make no difference. 1 is to get automatically from ISP, and the other is to manually set 8.8.8.8 and 8.8.8.4.
Using Fiddler to try to understand this. First time I try to browse to dji.com...
GET http://dji.com/ HTTP/1.1
Host: dji.com
Proxy-Connection: keep-alive
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9
The response is...
HTTP/1.1 502 Fiddler - DNS Lookup Failed
Date: Fri, 09 Jun 2023 15:48:57 GMT
Content-Type: text/html; charset=UTF-8
Connection: close
Cache-Control: no-cache, must-revalidate
Timestamp: 08:48:57.535
[Fiddler] DNS Lookup for "dji.com" failed. System.Net.Sockets.SocketException No such host is known
Then I immediately browse to dji.com again, and it connects completely without issue.
I am highly suspicious of the DNS provided by my router in this.
FWIW - This is my home computer, not on a domain, but rather a workgroup.
What may be causing this intermittent issue, how can I diagnose it, and more importantly how can I fix it?
Message 1 of 7
Guru
Re: Nighthawk X6 AC3200 Smart WiFi Router (R8000) DNS ISSUE
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browser are you using? Happens in different browsers?
What happens if you enable IPv6 (Auto) on the router, save and apply, then reboot the router and power cycle the ISP modem/ONT and all connected devices. Be sure to clear all browser caches as well.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 7
LeeGillie
I have xfinity/comcast as my ISP. I use my own xfinity approved modem:
The modem is: ARRIS Surfboard S33 DOCSIS 3.1 Multi-Gigabit Cable Modem | Approved for Comcast Xfinity, Cox, Spectrum & More | 1 & 2.5 Gbps Ports | 2.5 Gbps Max Internet Speeds | 4 OFDM Channel
https://www.amazon.com/gp/product/B08FMSC5WZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Cable is CAT 6.
Doesn't matter which browser. I am a software developer, and I see it my own applications connecting to the outside. Sometimes after DNS resolution failure, I run my program again, and it works perfectly.
Message 3 of 7
Guru
There is a long standing DNS issue on NGs R series routers. Been on going since and we have sent this to NG for review. Others came up with a work around to enable IPv6 (Auto) seems to help for most users. Something to try.
No idea if or when this will be finally fixed. We don't get that info here.
Message 4 of 7
LeeGillie
This may be it?  My IPV6 was disabled. I enabled it, and set to auto config. Will see what happens, and will report back here.
Thanks so much for this!
- Lee
Message 5 of 7
Guru
When you changed your DNS setting, did you also change the IPv6 DNS setting?
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 6 of 7
Kitsap
Master
- Lee
Like @plemans says, you also have to configure alternate DNS settings for IPv6.  Attached may help.
My setup: Comcast -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.70HF)
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 757 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
