Courtshier's avatar
Courtshier
Nighthawk X8 extender
Hello. I purchased a nighthawk x8 extender and it won’t set up in the app. It doesn’t connect no matter what I do. I have reset it. Done everything. Any advice?
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
    I would review the user manual and installation guide to to see if this helps as well.
    Thank you.
  • plemans's avatar
    You didn't give us much to go off.
    1. What extender is it? X8 isn't the model number. Check on the label.
    2. what router are you trying to connect it to?
    3. did you try setting it up using wps first?
    4. what actual error/issue is happening. Saying It doesn't connect no matter what you do doesn't tell us where the error is happening, where its failing, or even how you're trying. We need details to help you.
    5. If you just puchased it, it comes with 90 days of free support on new devices. To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
    • Courtshier's avatar
      Courtshier
      Thank you for your help. I am away from
      It now so I can’t write the model number. I am trying to connect it to a zXytel modem from Consolidated wifi. When I try to set up the extender in the nighthawk app. It says that it can’t find the extender and cannot connect to the extender wifi. I have registered the product. I tried connecting it wps as well. Pressing the wps button it it and then in the modem until it stops flashing. Am I doing something wrong?
      I then unplugged it and took it away to an area closer to where it needs to boost and still no reception. And the extender wifi network never shows up
      • plemans's avatar
        A little bit of a key in what model it is.
        Reason I say that is some of the models are mesh extenders. So if you set them up using wps, they setup using the same ssid as the router.
        They don't show up with a seperated ssid when setup using wps or the default configuration. You'd have to log into the router to see if its connected and whats its IP address is. You could use the IP address to access/manage it.
        So find out the model.
        You can also try logging into your router and checking under its attached devices page (or equivelent) to see if its connected.
        What are the led's on the extender showing (each, color, blinking, etc)
