- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk blocking SlingTV
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
Seemingly overnight, SlingTV is not working on any of my devices. I did a factory reset of the router and that did not work. I plugged my laptop PC directly into the ISP modem and SlingTV worked. Somewhere along the lines of the Nighthawk Router is SlingTV not working. I've contacted both SlingTV and my internet service provider. I've confirmed that my SlingTV account is working as I have no issues when using cellular data or from a different ISP/router altogether (relatives in another state).
I've seen some bits and pieces of help online, but nothing clear cut. It seems that I may have to do some port forwarding on my router, but I have no idea what port. Besides, that seems a bit overkill for what should be a simple service aimed at non-tech customers.
Any help is appreciated and I can provide quick feedback of solutions proposed!
Best,
Martin
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk blocking SlingTV
Whats the Mfr and model# of the ISP modem? Any built in router by chance.
If the service had been working and now it does, I presume that maybe the servce or service side could have had some intermittent issues and this would have not been a router issue.
If uPnP is enabled then now Port Forwarding configurations are needed.
@mnoah66wrote:Hello all,
Best,
Martin
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ISP modem is Comtrend VR-3030 (http://us.comtrend.com/products/vr-3030/)
The only thing I haven't done yet is a factory reset of the modem, but I fear that it won't work at all after I do that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
IT appears that your ISP Modem may have a built in router. I would have the ISP service make sure that this feature is diabled or the modem is fully bridged since you already have a router which is the NG router. Having two routers online can cause problems.
If the modem can't be bridge fully, use it's DMZ for the NG routers IP address it gets from the modem.
@mnoah66wrote:The ISP modem is Comtrend VR-3030 (http://us.comtrend.com/products/vr-3030/)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Am I to bridget the modem or my NG router? I currently cannot access the modem's GUI at 192.168.1.1 It redirects me to the NG Genie page...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact your ISP and ask for help and information regarding getting access to the modem.
The modems IP address will be different from 192.168.1.1 which the NG router uses.
Try 192.168.100.1
Contact your ISP.
@mnoah66wrote:Am I to bridget the modem or my NG router? I currently cannot access the modem's GUI at 192.168.1.1 It redirects me to the NG Genie page...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same problem which not allowed to connect the Sling TV through nET GEAR Nighthawk, I tried to connect to modem directly and it works.
Tried to connect using VPN and it works too.
JS
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model of the ISP modem? Built in router by chance?
@jsputrawrote:I'm having the same problem which not allowed to connect the Sling TV through nET GEAR Nighthawk, I tried to connect to modem directly and it works.
JS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is uPnP enabled on the router? Should be enabled.
Try setting NAT Filter from Secure to Open. Save settings. Power down the Sling device/app. Reboot the router fully. Then try the service again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
uPnP enabled
NAT Filter from Secure to Open. OPneed already
Saved and restart the apps but still no luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
it works for 1 weeks.
This problem starting this morning.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact the Sling service support and help about this. If nothing has changed with the router and it's been working up to this point, this is a service issue.
@jsputrawrote:it works for 1 weeks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great, thanks for trying anyway.
I just called Sling Support again just now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if you find out anything. Let them know that nothing has changed on the router and there service has been working up to this point.
@jsputrawrote:Great, thanks for trying anyway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll keep you posted.
For now will use VPN for Sling.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome! No such luck with me. My ISP said that my modem is not a modem/router, it's only a modem. So I am still at a loss. I suppose I'll enable the VPN on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad Sling got it working.
Enjoy.
Best,
Martin
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure why the modem only will affected the connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
