Orbi WiFi 7 RBE973
Reply
Nighthawk won't connect to FEIT Smartplug BPPlug/WIFi/3
Dougster12
I can't get my FEIT Wifi Smart Plug to cennect with my network Nighthawk Router MR 60
I get a message "Device Installation Timeout" on the FEIT install app.
Message 1 of 5
Guru
Re: Nighthawk won't connect to FEIT Smartplug BPPlug/WIFi/3
A couple things to try.
1. Not sure if the MR series supports wpa3 but I've found a few smart devices that struggle with it. If you're using wpa3, try disabling it and using wpa2
2. make sure your phone is connected to the 2.4ghz during setup. It shouldn't need to except for lazy coding on the app makers for devices that are only 2.4ghz capable.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
If you do need to know what the MR60 is capable of on the wifi front, try the appropriate section.
Nighthawk Mesh System - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 5
Dougster12
I only see one WiFi, no eparate 2.8ghz wifi.
Message 4 of 5
Guru
The NH MESH system broadcases 1 SSID name for both 2.4 and 5Ghz radios. Its based on a Smart Connect wifi system.
There will be more information and help over in the NH MESH forum.
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 560 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
