- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ports 465 and 587 closed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess I would try again to configure a custom email server configuration. If you are using Gmail, for example, below are the SMTP settings. I would try port 587 first and 465 second. I would set encryption to required. If you are set up with two-factor authentication on your Gmail account, you will have to go to Google Account -> Security -> App Passwords and create an Application Specific Password that you will then enter in the password box of the Lorex SMTP configuration. The Receiver# address is the email account to which you want the alert delivered.
Outgoing Mail (SMTP) Server |
smtp.gmail.com Requires SSL: Yes Requires TLS: Yes (if available) Requires Authentication: Yes Port for SSL: 465 Port for TLS/STARTTLS: 587 |
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ports 465 and 587 closed
Greetings. So your Lorex Camera has a built in client or relay?
One way:
Assign the camera with a static IP
Forward ports 465 and/or 587 to that IP
This should allow traffic to pass.
TELNET might help with troubleshooting to see if you can connect to the mail server. If you provide more specific information about the hardware, it might be helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think you are getting bad advice from Lorex tech support. When sending (SMTP) encrypted email, the outgoing tcp port will be 587 (preferred) or 465. The router will not block these outgoing tcp connections. Those ports will be blocked by default for incoming connections, however. You would only open these ports if you were running an email server on your home network, which is not what you need for the cameras.
My guess is that this has nothing to do with your router, but that you have configured the outgoing email incorrectly in the Lorex app. Did you try the Lorex "default" email setting or did you try a custom setting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which Lorex system do you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Manual is at https://www.lorextechnology.com/downloads/security-camera-system/LNK716394B/LNK7000_SERIES_MANUAL_EN... and on page 72 is the 2 ways to do this. Which are you using? If you use the one on page 74 it appears to be to me the same way the R8000 sends out its log via e-mail? Can you send out the router log? If the router IS blocking those ports you shouldn't be able to.
It is normal for port 587 to be blocked for packets coming in, but not going out. If it were, you couldn't send e-mail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
