XMAN512's avatar
XMAN512
R7000 Intermitting Dropping WIFI Daily
My Netgear Nighthawk R7000 continues to drop signal throughout the day. Intermitting. I have read other Netgear Community news feeds. It advises to downgrading to version 1.0.9.42. Hardwired connection and factory reset the router once its updated. Can someone please confirm if these are the correct steps to solution.
  • > Model: R7000|AC1900 Smart WIFI Router
       Firmware version?  Connected to what?
    > My Netgear Nighthawk R7000 continues to drop signal [...]
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  Further reading might not hurt,
    either.
       What, exactly, does "drop signal" mean to you?  _Which_ "signal"?  Is
    the connection between your ISP and the R7000 lost?  Or between the
    R7000 and your (unspecified, connected someway) computer/device?  Or
    what, exactly?
    > [...] I have read other Netgear Community news feeds. [...]
       Thanks for the helpful links.
    > [...] It advises to downgrading to version 1.0.9.42. [...]
       "It"?  Which version(s) have you tried?
          https://community.netgear.com/t5/x/x/m-p/2069376#M186506
    > [...] Can someone please confirm if these are the correct steps to
    > solution.
       Judging a "solution" can be unreliable without a useful problem
    description.  Why not run the experiment?
  • I downgraded my firmware to the 42 for my Netgear nighthawk. I was hardwired in my router when I updated my firmware. Does that make sense
    • antinode's avatar
      antinode
      Guru
      > [...] Does that make sense
         "make sense"?  I understand what it meant.  Are you asking if it
      makes sense to do that?  I'd prbabably try a recent firmware version
      (like, say, the latest Hot Fix) before going backward that far.
         But, having gotten exactly no answers to any of my questions, I know
      no more now than I knew before.
