Orbi WiFi 7 RBE973
Reply
R7000 Unable to save to USB after updating to ver. 1.0.12.216
GumboKen
After updating to version 1.0.12.216 I am unable to save to the \\readyshare USB.  I can read from it, but I cannot save to it.  Previously when I would have problems with just generally accessing the USB, a reboot would take care of the problem.  But now restarting or rebooting does not fix this.  I'm sure I could take out the USB stick, connect it to my computer, write to it, and replug it into R7000, but that is bypassing part of the usefulness of \\readyshare.  Any suggestions on what else I can try to get saving to USB to work again?  Any others having this problem with this version?
Ken
Message 1 of 4
Accepted Solutions
GumboKen
Re: R7000 Unable to save to USB after updating to ver. 1.0.12.216
After searching and reading general problems similar to this, I believe the problem is due to the size of the file I was trying to transfer.  One comment said that doing a transfer across their network seems to have a problem when the file size is around 2GB; the file I wanted to transfer is 1.8GB.  I have transferred a group of files that totaled much larger than 2GB, but I don't believe I've ever tried to transfer a single file this large before.
So I just removed the USB stick, copied the file to it, and reinserted it into the router.
Message 3 of 4
All Replies
Guru
Any progress on this?
Try a factory reset and setup from scratch?
Has this worked before?
Ken
Message 2 of 4
GumboKen
Message 3 of 4
Guru
Good to know. Thanks for letting us know.
Enjoy.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 930 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
