Orbi WiFi 7 RBE973
Reply
R7000 can't access setting after setting up VPN
ooeemusic
I set up thr R7000 last night because I recently started using express VPN. I followed the directions to set up the router and then the directions to set the VPN up. I now only have access to some of the routers setting through the express VPN router dashboard. I assume this is because it has changed the routers address, but I can't use the nighthawk app because of it and I can't get netgear genie to login even with the new IP address. Did I do something wrong in the set up? Or is this just how it works with a VPN that has it's own dashboard?
Message 1 of 4
antinode
Guru
Re: R7000 can't access setting after setting up VPN
> [...] I followed the directions [...]
   _Which_ "the directions"?
> [...] I recently started using express VPN. [...]
   If you installed ExpressVPN firmware on your R7000, then I would not
be amazed if some features which are specific to Netgear firmware no
longer work as before.
> [...] Or is this just how it works with a VPN that has it's own
> dashboard? [...]
   That would be another way to phrase it.  ("its", by the way.)
Message 2 of 4
ooeemusic
Directions = the directions the app gives you to set up the router and the directions express VPN gives you to set up the VPN on the router.
Message 3 of 4
antinode
Guru
   "the app"?  But, in any case, if you install non-Netgear firmware on
your Netgear router, then many things might change.
> [...] the directions express VPN gives you to set up the VPN on the
> router.
   Thanks for the helpful link.  But, in any case, if you have problems
when using third-party firmware, then you might best ask the third
party about them.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 678 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
