- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 ethernet devices missing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure when this started happening but when I go into the web GUI of the R7000 and attached devices all my wireless clients are displayed. But, my ethernet devices are not - the router status lights show that ethernet connections are linked up and flickering to show activity.
I have also noticed that the latest version of the Nighthawk app on IOS doesn't let me login to the router - it 'times out' when entering the password.
Any ideas/solutions would be gratefully received.
Cheers
N.B. I am not on the latest software as that is just not very stable for me. I am on Firmware Version
V1.0.11.130_10.2.118
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 ethernet devices missing
I don't thing the .134 (latest) version changed attached devices but you can try upgrading to it.
https://www.netgear.com/support/product/r7000.aspx
if it doesn't help, you can try factory resetting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried going to .134 but it was very bad.
So I am back to .130 but suddenly my ethernet devices aren't staying connected.
They seem to be connected but when in sleep the devices leave the network instead of staying connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you do a factory reset after the changes? the R7000 has responded pretty favorably to resetting after changing firmware. I'd advise during the reinstall to not use a backup configuration
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I actually ended up doing 2 factory reboots and its still the same. So cant see the point in another.
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry, didn't know if you did or not.
the version thats been the most stable is pretty old. The one we always used to recommend was 1.0.9.42
The .126 version was also fairly stable for those devices it worked well on.
It seems like there's a small percentage of the r7000's that struggle with firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Obviously I want to avoid going too far back for security concerns.
What would be your advice here? Which version?
- Mark as New
- Bookmark
- Subscribe
- Permalink
so they don't show up in the attached devices list. Do they show in the access control list (doesn't have to be enabled).
If they do, I'd just leave it as is.
If they don't, then I'd try downgrading
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using?
I've got v.134 loaded on my R7000 and all my devices appear, wired and wireless when I had it online for a week or so:
I use MS Edge here.
Please take a screen capture of what your seeing and post it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is connected as I am using it, but the GUI doesn't show its connected.
It is using the IP address 192.168.x.11 and a smart switch I have is on 2.4g wifi and using 192.168.x.11
How do I change this? And could this be the cause?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:I don't thing the .134 (latest) version changed attached devices but you can try upgrading to it.
yeah, i have tried it but it was not helpful for me so there was only one option that was factory resetting i do this and got.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have managed to get the .134 FW installed and seems stable.
I removed a meross smart plug that i added into the mix a few days ago and the ethernet devices are staying connected.
Anybody know why this type of device would cause the ethernet devices to stop functioning?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried safari and edge and chrome
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe causing some noise or interferences. Something to contact the Mfr of this device about and see if they have any information regarding there product.
Thanks
