Michaeal's avatar
Michaeal
R7000 half internet speed (upload 600, download only under 300)
I have some issue with r7000.
my download speed was limited under 300 mbps.
I have try fw 0.42, and many other fw but cannot fix this issue.
I have off QOS.
current fw is 0.216.
anybody have solution?
thank you for helping me out.
  • plemans's avatar
    If you ever had parental controls, access controls, qos, or traffic monitoring on, factory reset and reinstall.
    Make sure not to enable those services.
    Then test it.
    • Michaeal's avatar
      Michaeal
      I have off all of them, but it notworking.
      let me try factory reset.
    • Michaeal's avatar
      Michaeal
      f6600pr7000I have do factory reset but it still not working
      I take a result from F6600p zte (picture 1)
      I don't known what wrong but seem they limited download speed around 300mbps (picture 2)
      look like they had limited, but I off all feature QOS, parent control, access control already
      • FURRYe38's avatar
        What is the brand and model# ISP Modem or ONT the router is connected too?
        Here is my R7000 results connected to a NG CM3000 cable modem:
        Wired PC behind the R7000:
        R7000 onboard speed test which has always never been accurate:
        No Armor, Access Cntrols, Circle, Traffic Meter enabled.
        FW updated and factory reset and setup from scratch.
