Orbi WiFi 7 RBE973
Reply
R8000P Nighthawk Router is causing delay internet, but works great when connected direct to modem
notgoodatthis
I have my PC connect to my Nighthawk router with a LAN cable and my router is connected to my cable modem.  When I access any website there is about a second or so delay before it goes to the website.  If I'm in say my online banking and want to redirect to billpay it usually won't do it at all.  I use Quickbooks for work and if I try to do an online backup it always fails.
HOWEVER - if I unplug my pc from the Nighthawk and plug directly into the cable modem.....it always works.   What am I doing wrong?   Also, it didn't always use to do this.
Message 1 of 8
Accepted Solutions
Guru
Re: R8000P Nighthawk Router is causing delay internet, but works great when connected direct to mo
Power OFF the ISP Modem for 1 minute then back ON. Then walk thru the set wizard using a wired PC and web browser at 192.168.1.1
Message 8 of 8
All Replies
Guru
Message 2 of 8
notgoodatthis
Firmware is V1.4.3.88_1.3.50
Cable modem is Netgear CM500
Message 3 of 8
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is Armor, Circle, or Traffic Meter enabled or has those ever been enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 4 of 8
notgoodatthis
Installed new Cat 6 cable between the router and modem
powered off everything as said
turned back on
still has same dilemma
Message 5 of 8
Kitsap
Master
Who is your ISP?
Do they support IPv6?  If yes, be sure and enable it in advance settings on your router.
You might have to check out some alternate Domain Name Servers from those provided by your ISP.
Message 6 of 8
notgoodatthis
I appreciate all of the help but still not having much success.   Is there a non wireless router (wired router) or possibly a switch that might be better?   At one time this R8000P did not give me any issues but I live in a very small town and not many computer savvy people around here to help.
Message 7 of 8
Guru
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1412 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
