fouadhallal's avatar
fouadhallal
R8000P wifi speeds
I noticed recently that Wifi speeds goes down every couple of days.  Instead of getting about 500mbps, I get about 40mbps.  I reboot the router from the App.  After reboot, I get the high speed.  Ir seems that I need to reboot the router every 1 or 2 days.  Any hints on what may be going on?  The router is not that old.  I have installed it about a year ago.  Any suggestions are appreciated.
Thanks
  • plemans's avatar
    are you using smart connect?
    If so, your device might be connecting to the 2.4ghz and not the 5ghz. 2.4ghz is a lot slower. That 40mbps is more along the lines of what you'd get.
    • fouadhallal's avatar
      fouadhallal
      Thank you for your response.
      Is smart connect a setting on the router?
      The thing is, after I reboot the router, the same device get more than 300mbps.  It then degrades after a day or so
      I checked other solutions and they recommended specifying certain channels for the wifi, which I did.  That didn't help my issue at all.
